Восстановления IP-камер (пока неуспешно)
Добавлено: Вт дек 26, 2023 9:33 am
https://aliexpress.ru/item/32960960518.html
https://forum.videon.spb.ru/viewtopic.p ... 00#p156300
ivg-85hf20py-s
h200108151024S03052
blk16ev2-0307-38x38-b v1.01
Serial port COM5 opened
System startup
Uncompress Ok!
U-Boot 2016.11-g2fc5f58-dirty (Sep 06 2019 - 15:13:30 +0800)hi3516ev200
Relocation Offset is: 0371b000
Relocating to 43f1b000, new gd at 43edaef0, sp at 43edaed0
SPI Nor: eFlashType: 24.
Flash Name: XM_XT25F64B-S{0xB4017), 0x800000.
@hifmc_spi_nor_probe(), XmSpiNor_ProtMgr_probe(): OK.
@XmSpiNor_enableQuadMode(), Quad was Disabled, SRx: [2, 0x0].
CONFIG_CLOSE_SPI_8PIN_4IO = y.
read->iftype[0: STD, 1: DUAL, 2: DIO, 3: QUAD, 4: QIO]: 1.
Current level[6], lock_level_max:7.
at xm_get_locked_range() sr:0x18, level:6.
lk[6 => 0x400000]
SRx val: {[1, 0x38], [1, 0x0], [0, 0x0], [0, 0x0]}.
In: serial
Out: serial
Err: serial
Net: eth0
Hit ctrl+c to stop autoboot: 0
@do_spi_flash_probe() flash->erase_size:65536
device 0 offset 0x40000, size 0x550000
SF: 5570560 bytes @ 0x40000 Read: OK
srcAddr 0x43000000, dstAddr 0x42000000
created_inode 0x43edb810
find_squashfs_file: name bin, start_block 0, offset 2001, type 1
find_squashfs_file: name boot, start_block 0, offset 2181, type 1
read inode: name boot, sb 0, of 2181, type 1
find_squashfs_file: name uImage, start_block 0, offset 2033, type 2
read inode: name uImage, sb 0, of 2033, type 2
write_file: regular file, blocks 29
len 1861831
### FS load complete: 1861831 bytes loaded to 0x42000000
## Booting kernel from Legacy Image at 42000000 ...
Image Name: Linux-4.9.37
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1861767 Bytes = 1.8 MiB
Load Address: 40008000
Entry Point: 40008000
Loading Kernel Image ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
ivg-85hf20py-s
h200108151024S03052
System startup
Uncompress Ok!
lk[6 => 0x400000]
In: serial
Out: serial
Err: serial
Net: eth0
len 1861831
Starting kernel ...
