Настройка IPTV Portal PC NG через TP LINK 3600
Добавлено: Пн фев 24, 2014 9:40 pm
/etc/init.d/igmpproxy stopКод: Выделить всё
rm /etc/igmpproxy.confКод: Выделить всё
rm /etc/config/igmpproxyКод: Выделить всё
echo "config igmpproxy
option quickleave 1
config phyint
option network local
option direction upstream
list altnet 89.20.157.0/24
list altnet 192.168.1.0/24
list altnet 212.1.254.0/24
config phyint
option network lan
option direction downstream" >/etc/config/igmpproxy
echo "quickleave
phyint eth0.2 upstream ratelimit 0 threshold 1
phyint br-lan downstream ratelimit 0 threshold 1" > /etc/igmpproxy.conf
/etc/init.d/igmpproxy enable
/etc/init.d/igmpproxy startКод: Выделить всё
root@OpenWrt:~# ps |grep igmpproxy
2588 root 812 S /usr/sbin/igmpproxy /etc/igmpproxy.conf
5180 root 1500 S grep igmpproxy
root@OpenWrt:~#
echo "config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
option target 'ACCEPT'
config rule
option name 'Allow-IPTV-IGMPPROXY'
option src 'wan'
option dest 'lan'
option proto 'udp'
option dest_ip '233.49.170.0/24'" >>/etc/config/firewall
echo "config interface 'local'
option proto 'dhcp'
option ifname 'eth0.2'
option defaultroute '0'
option peerdns '0'" >> /etc/config/network
config zone
option name 'wan'
option network 'wan'
option input 'REJECT'
option output 'ACCEPT'
option forward 'REJECT'
option masq '1'
option mtu_fix '1'
option network 'wan local'
